Crown Power amp directly connected to laptop -not getting enough power
Hi Guys,
I connected Crown XLS2002 directly to Laptop using 3.5jack to 2RCA cable.
I am using this to drive subwoofers.
Input sensitivity is set to .755 in crown amp.
Power output per channel is 650W@4 ohms
The subwoofers are 300W @ 4 ohms
Somehow I feel the amp is not delivering enough power.
Even if I crank full volume, the indicator light is glowing -20 only
I suspect the laptop output signal is not strong enough.
Any solution for this?
Should I use a preamp? If so which preamp?
Any suggestions please ...
Thanks & Regards
Audfrknaveen
Headphone outputs often don’t put out enough signal - they are intended to drive 32 ohm loads just loud enough, but not ear splitting. The ART Cleanbox will get the levels high enough to drive a real PA rig, but they’re not really super “clean”. “Clean enough” often, but if you’re picky you’ll want something better.
