So the rails are +-30 vdc. Is that what you get on + & - terminals of C1, C2?
Warning to newbies, work only with one hand when checking with the power on. Use alligator clip to connect DVM negative to speaker return. >24 VDC across your heart can stop it. Wear no jewelry on hands or neck. 1 vdc @ 30 amps can burn your flesh to charcoal. Touch no metal with flesh until checked <1vdc and unit unplugged from AC.
Volume pots often wear out on old amps.
You can download service manual from eserviceinfo.com
I just downloaded the service manual, C101 and C201 seem like a good place to start looking.
Use bipolar types only. They're overdue for replacement anyway.
What role does that cap play exactly?
Input blocking capacitor, just after the level control.
- Crown D75 snap, crackle, pops
