Crossovers for my 3 way Seas speakers...
Help!, i hae a problem
i have been adding the items for the pms xover to my cart in europe audio..
Poor Man'
the list of parts includes two 6.8uf and two 1.5uf capacitors....
these dont exist in the schemetic
so the only ones in the schemetic are the 33 15 and 10uf values
im in the process of filling my shoping cart... what should i do?
The schematic is probably correct, the parts list not. You notice there were many iterations to arrive at the current one (version 5).
What I'd do however is to send a quick mail to Troels just to be sure.
Ralf
Thanks, Thats a good idea, I will try emailing Troels,
Its odd because the picture of the crossover below shows additional Caps, again. and also 10w resisters, when the parts list says 5w resisters,
I was going to go with 10w ones anyway, seems more logical
If the TDC doesnt merge well with the mid, I may have to alter the network over time, or if all else fails change to the TFF.
Troels started with the TDC, then changed to the TFF, he still wasnt happy so he then altered the xover down to 3khz...then he was happy, So it stands to reason that the TDC would also have sounded good if he tryed it again, as the issue was probubly due to the mid playing too high.
Im quite happy really, because at the start of my project I looked at the drivers and instantly decided on 500hz and 3000hz as xover points. quite a lucky coincidence. me hopes
