Hi, I am new to this forum, and this is my first post... So, hello to all.
Question : I'm making my first crossovers, and will be soldering with silver 96/4 solder. Should I use a flux/resin while soldering? If so, any recommendations as to brand/type?
Also, if I do use a flux, even if it's a no-clean flux, what should I use to clean up the soldered joints?
Thanks!
Thanks!
If you do use separate flux, and I do, clean up with alcohol (methyl hydrate is fine) and q-tips and/or toothbrush and a soft cloth. Then use compressed air as there are likely to be some stray strands.
