Crossover Resistors.. Advice Needed
Hello,
I have the following crossover to build for a MTM TL using the Vifa p17/d25 combo however I am having trouble sourcing the necessary resistors. All parts have been obtained apart from these.
I can obtain resistors that are close to the reccommended values locally - if I use these following values for some of the resistors, what effect would this have on the crossover?
R3 changes from 20.0ohm --> 22.0ohm
R8 changes from 0.30ohm --> 0.27ohm
R13 changes from 25.0ohm --> 27.0 ohm
As you can tell, I am a novice when it comes to crossover designs. All credit goes to Zaph for the crossover design
Thankyou, any help would be very much appreciated.
Phillip
