Crossover Recommendations for a Small Subwoofer
Hello,
I have two Tectonic TEBM65C20F-8 3-1/2" BMR Full-Range Speaker 8 Ohm speakers I want to supplement with a Tang Band W5-1138SMF 5-1/4" Paper Cone Subwoofer Speaker to add more bass response. I plan to put all three in a three chambered enclosure for use in a bedroom/office setting. I'm looking for a suitable preassembled crossover that will work for this pairing. I would like the crossover frequency to be around 200 Hz - 300 Hz based on the various speaker specs and modeling curves. The FR speakers are 8 Ohm, and the subwoofer is 4 Ohm.
I'm considering using a Parts Express 100 Hz Low Pass 8 Ohm Crossover Part #266-446. This is an 8 Ohm crossover. If I use two of these crossovers with that subwoofer (one for each FR speaker), can I reasonably expect the crossover frequency to increase from 100 Hz to somewhere near my desired 200-300 Hz? Are there any concerns to consider about doing this?
Recommendations for something else to consider are appreciated.
Thanks.
100 Hz Crossover
TEBM65C20F-8
W5-1138SMF
Standard "textbook" calculator crossovers tend to fail to work as intended once the impedance changes around crossover frequency - which will be the case with most subwoofers. It usually leads to a bloated upper bass (corresponding to the higher impedance peak of ported enclosures).
Solution: try an active system!
Reactions: dreyerdr
Looks good, but you will need amps after the x-over
After researching it more, it appears that I'm stuck in an "old school" way of thinking about subwoofers. Admittedly, most of my experience with it was building subwoofers with my dad almost forty years ago. I'm just now getting back into it for fun, and have a lot to catch up on.
There's a number of ways I could go, but it seems that for my application, some sort of small 2.1 plate amplifier with built-in crossover frequency adjustment and possibly high and low volume control would be the way to go.
I'm looking at something like this now.
https://www.parts-express.com/Lepai...i-Plate-Amplifier-TPA3118-310-4002?quantity=1
Reactions: stv
Have a look here:
Reactions: dreyerdr
