Crossfire TEK 150.2
Amp has no regulated voltages on op-amps..
As you can see someone has attempted to repair this already..
Both 1N4744A's test fine..
Does anyone know the value of the resistors that belong here??
Since someone has been in it before im not sure if theese resistors are the correct value..
I pulled R100 to check to see if it was in tolorance that was also replaced at some point with a 2.2k ohm..
Q101 and 201 were also pulled to check when photo was taken..
So im wondering if anyone know the correct values of the 2 resistors with arrows pointing to them and if the 2.2K in R100 spot is correct?
From what I can see, the circuit is s simple shunt regulator. One end of each Zener will connect to a resistor that has its other terminal connected to the power supply rails. Those terminals of the Zeners/resistors will connect to the power supply pins of the op-amps.
The other legs of the Zeners will connect to the secondary ground.
One end of R100 appears to be connected to the rail. Is the other leg connected to the ground side of the Zener or to the op-amp side of the Zener?
