The link to the "Headphone Amplifier Evaluation Board" by Dimitri is down. Perhaps this is the correct document: https://www.angelfire.com/az3/dimitri/images/Headphone_Amplifier_Evaluation_Board.pdf
In post 10 of this thread, you refer us to references 4 and 5 in that document. However, the link to the "F5‐HA Discrete All FET Class A Headphone Amplifier" is also dead (provides a strange redirect). Where can this document be accessed?
Thanks,
Bryan
Thanks,
Bryan
Document from 8 years ago.
First hit on google :
http://xen-audio.com/documents/f5ha/F5-HA Description V1.4.pdf
I have no problems retrieving. Not sure why you cannot.
Patrick
Patrick
Many of the previous links no longer work after platform migration.
You need to delete "page-xx#post" from those links and replace by "post-"
As an example :
www.diyaudio.com/community/threads/f5-headamp.271926/page-10#post4671587
should now be
www.diyaudio.com/community/threads/f5-headamp.271926/post-4671587
Patrick
As an example :
should now be
Patrick
Maybe a character encoding issue? A cut and paste of the link from Dimitri's PDF gives an odd redirect. However, if typed in directly, it works.I have no problems retrieving. Not sure why you cannot.
-Bryan
