hi all
i have gathered the parts for a f4 build using auto formers for my frontend and am going to be removing the jfets at the input (crippled as they say)
can i use a higher rail voltage now that the jfets are removed ?
i ask as i already have 2 potted 500va 25/0/25 toroids i,d like to use rather than buy new 18/0/18 toroids
i will also only be using 1x irfp240 /irfp9240 per channel instead of the 3x used with the normal f4 and would like to know if this is safe with the higher rails
cheers sheafer
cheers sheafer
thanks Zen Mod
great ,saves me mucho money on the toroids
i will no doubt have more questions as i get further through the build
many thanks
many thanks
no probs
i am using 1x conrad 350mm x 150 per side , i am hoping to bias the hell out of this new amp 😀
the sinks were just right for my aleph 2 which ran on the same rail voltage with the bias resistors removed (40 to 50 degres)
i,m hoping only running one pair output with the f4 will allow a higher bias to be run with the above sinks
cheers
cheers
