Crescendo 17k
Try heating and freezing (canned air inverted) various components. Have the FETs clamped to the heatsink when doing this.
I don't have a time that you should do this. Connect it to an extra supply with a 10 amp fuse and let it idle while you work on other amplifiers. If there's no hurry, do this for a couple of days.
I found the issue with the amp . Not sure how to fix the issue .
No matter how short you cut the middle legs of the fets I have them even with the bottom of the board now .
The issue is the bottom of the board somehow touches the heatsink and grounds out the board to the heatsink so I have battery plus touching ground
I think that’s what’s grounding out I don’t see anything touching .
What’s happening is everything is fine until I start putting the spring clamps back on and as soon as I do battery + shorts to the heatsink . I’ve checked and triple checked and so t see anything touching but same result as soon as the spring clamps are being installed the battery + shorts to the heatsink
