Crecendo 12K
Perry, do you have a page on how to check the dead time of the output of the amp and how to adjust if needed? Working on a Crescendo 12K. Generic Korean half bridge. The amps been repaired by someone before. When I got the amp, the power supply was burned up and outputs shorted. One bank of output shorted on two of the amp sections. As you can see in the pick. I've removed the bad outputs. Is it necessary to replace the banks of good outputs? Also replaced the driver IC on the driver board. I'm using hot air now. It was blown up. I'm going to up the value of the cap on the turn on signal. Delaying the turn on giving the rails more time to come up before the drive. Upping from a 22uf to a 33uf. I understand it could have been abused before. Just trying to cover my bases.
Yes the far left transistor is the 12v reg.
Replaced the driver board and transistors. Powered it up and it blew 4 transistors on the other side of the board. Which is strange because it blew the same driver chip. That chip doesn't even drive the side that blew. Currently replacing both driver chips on the driver boar. All outputs are out. Gonna check the drive signals at the input of the driver chips and at the outputs. I know I can't check the high side drive without adding a battery.
Quick question. The outputs in amps like these are usually grouped in banks of four driven by the driver. I know if an output shorts all outputs in that bank should be changed because the others could have been weakened. Is it necessary to change all the outputs in banks that didn't short. I hope this makes sense.
If the other half is working perfectly, it may be OK. This is where you make an executive decision... Replace ALL and know that everything is right or replace half and have a pretty good idea that all is right. If this were one of the amps that used the 7812 for the 21844 regulator I'd, at least, replace the 21844. I've never had to repair one with this regulator.
caraudioguy2100 I am so sorry for the confusion. I was looking at an Ampere 8K. Yes the Crecendo 12K does have that diode. I have two of those I'm finishing up on. Thanks for the heads up about the diode. I will check them. What's the value of the zener?
