CRC PSU PCB for Class A/AB amps
Hello,
I am planning to make a CRC PSU for Class A (Jean Hiraga), which can also be used for class AB.
The PCB layout is made in 2 styles.
I have made 2 layouts and wish to know which one is the recommended one.
Attached are the schematic, Layout A, and Layout B.
Thanks and regards,
Sumesh
Both layouts are worse on force current routing. It will work but filter and storage capacitors are not routed correctly.
It needs to go from pad to pad to force current flow throught capacitor. Ground and rail connections needs wider track as there will be flowing 5A max current. At schematic there is missing rc filter at output....add kelvin sensing at output connections and many ground connectors...routing pcb for psu is not as easy task...waiting for new revisited layout....
Reactions: sumeshak
If you're hoping to implement Bob Cordell's excellent suggestion "Star On Star Grounding" you'll want to route the electrolytic caps and the common (0V) signal as shown in the attached figure. It appears to me that implementing this would require fewer edits to Layout B than to Layout A. Both require edits; but I think A requires more edits.
_
Reactions: sumeshak
_
HI,
I have changed the tracks to get 2-star points. Please find the image below:
Expecting your feedback.
Thanks for the input.
Can you please elaborate on how to force current routing? a diagram would be of great help.
I shall widen the ground track once the layout is finalized.
The ingress current from the bridge rectifier is very dirty. It should reach the capacitor via a segregated path with respect to the egress current path, which must have less ripple (and RF noise), if the capacitor is given the opportunity to work at its best. So, the below design is not good... the tracks are mixed together:
Study the PCB layout of Japanese amplifiers - Marantz for example.
With power amps, it is easier to achieve correct power supply capacitor topology and grounding without the PCB.... but the PCB looks better...
Edit: two capacitors can be connected together via a thick/wide PCB track, and then assumed to be a single one (single capacitor)... but the above rule should be respected... hence, it is easier to get the thing right without the PCB... especially if the capacitors with the screw terminals are chosen; you get everything right by default 🙂
Reactions: sumeshak
