First time Aleph builder seeking advice. I am building the Brian GT mini as a 3 or a 5...
1. Would you do CLC or CRC power?
2. Should I be concerned that the power boards place the transistors three up and closely spaced... Would it help to spread them out???
CLC...
Personally, I prefer a CLC power supply, I played with both and always got better results from the CLC. However, the L part is going to be much more expensive than the R part.
With respect to the question of the transistors being mounted close together, it kind of depends on your heatsinks ability to 'spread' the heat...if the mounting surface is very thick and the heat distribution is good, you probably don't have to worry as much about whether the transistors are perfectly spaced.
It can't hurt to spread them, but I have predrilled and tapped heatsinks, so I put mine in the obvious, convenient spots...not evenly spaced...
HTH
Stuart
HTH
Stuart
I was thinking that the perfect solution would be to mount a 1/4 x 3 x 6" coper strip on the heatsinks. I can have the copper ground and the heatsink ground for a perfect fit. Add a little thermal spooge and bob's you uncle....
copper plate works well...
...as long as you don't trap any air underneath. You are right about needing the thermal goo, apparently dry metal to metal is not necessarily a great thermal contact.
Stuart
Stuart
