I have a problem with my CD player. It is a CDM4/31 type mounted in B&O Beocenter 8000.
It plays perfectly for apporx. 30 minutes. After that the sound distorts and crackling sound occurs in the high frequencies.
Does anyboy have an idea wht the problem can be? and how to fix it.
Thanks,
Thomas
Thanks,
Thomas
Hi Thomas,
If you cool the circuit off, does it play longer before it starts? Removing the cover (difficult on B&O) may do this.
I have seen everything from the brown glue cause this to digital filters, DSP chips and DACs. Mistracking may also cause distorted sound, as will a low HF signal.
Can you record the sound in a sound file (ie MP3) and attach? This may give us more clues.
-Chris
-Chris
