cracked speaker
Hello All, I'm posing to get some opinions on my most recent woe from people who know speakers better than I do.
I dropped one of my surround speakers (Goldenear Sat3). The plastic case was not happy about this, resulting in a few inch long crack and a chip out of the corner of the back of the housing. I could glue the chip back in.
Do you think this will have a big impact on the sound? Can it be fixed?
The place I bought them from took the attitude that it's a cheap speaker, and should just be replaced, but $250 isn't that cheap. He didn't think it would have much effect on the sound, but it seems that might be because he thinks it's a bottom end speaker to begin with. The whole back unscrews easily, and they will look into a replacement next week.
Basically, how important is the cabinet sealing at frequencies above 100Hz?
Thanks,
Mark
Hello, i do not know. Thou can play back something on it and compare to an unspoiled specimen. Some music or pink noise to listen for balancing issues, and a slow low-frequency sine sweep to listen for hissing noises. But beware, do not thermically overload it. Or better yet, just glue it back together. Most plastic can be glued pretty good with glue based on organic solvents. By organic i mean a hydrocarbon such as acetone. Just make sure there is nothing left inside the box rattling. Uli
Thanks. I have listened to it, and it sounds fine, but I have not A B tested it.
I was thinking superglue, but I do have acetone. Which would be better? Or, maybe modeling cement?
It's almost funny, I've been agonizing over pulling 12, 14 or 16 AWG wire in the walls, and then I go and drop a speaker, which probably has a bigger effect than the differences in wire.
Thanks,
Mark
Get some 2-part epoxy to seal the cabinet and feel it. If it feels strong and inflexible, you are done. If however it feels weak, you may need to reinforce internally with a wooden strip or metal tube across the break.
Having it air tight will prevent lots of issues. :) So yes, you should make sure it's air-tight, but it's super easy with epoxy. Hot glue would also work but it may be too flexible, as would any caulks. Probably you want an epoxy that says it's sand-able. That means it dries hard enough to provide support.
You may also need a small clamp to hold things tight as they dry.
Tip: Get disposable plastic gloves. :)
Best,
Erik
