DJNUBZ said:Are you saying that two 93db/w/m speakers run in series is still 93db/w/m and not 96db/w/m? Could you explain this? I thought that for each doubling of drivers you get a 3db increese and that weither they were in series or parrallel didn't matte
It threw me for a loop when essentially the same thing was posted in another thread. I went back to 1st principals (and ignoring change in impedance) couldn't convince myself it wasn't true. So i've been sitting back holding my tongue & noodling on it. I'll be interested to see if GMs explaination snaps things into place.
dave
DJNUBZ said:
Are you saying that two 93db/w/m speakers run in series is still 93db/w/m and not 96db/w/m? Could you explain this? I thought that for each doubling of drivers you get a 3db increese and that weither they were in series or parrallel didn't matter.
Did we decide if that first graph was modeled correctly on the vas?
Greets!
If you mean Dave's, it appears he assumed that 0.78 is 'liters', but I believe it's 'ft^3' so while the basic response is ~right if there's no series R, the amplitude of the peak won't be as high. Still, it will be severely underdamped so some form of series R will be required to flatten out the response.
?! What's series connected got to do with any of this? As I've noted, all my calcs, observations assumes either none or various amounts of resistance in series with parallel connected midbass drivers.
That said, if two 93 dB/W/m (AKA 93 dB/~2.83 V/m) drivers are wired in series, then we now have two drivers that sum to 96 dB/2 W/m, so yes, their combined efficiency will stay 93 dB/W/m due to the 3 dB loss from a 2x higher R which negates the +3 dB gained over whatever BW the two are closely coupled acoustically (<WL/pi, or more commonly referred to as <1/3 WL).
Drivers in series:
10*log(2/1) = ~ +3 dB due to doubling Sd
10*log(4.9/9.8) = ~ -3 dB due to series wiring
net change = o dB
Drivers in parallel:
10*log(4.9/2.45) = ~ +3 dB due to series wiring
net change = +6 dB
Another advantage of parallel Vs series wired is Le halves Vs doubling, so parallel wired has a flatter response (better acoustic phase).
GM
GM
Thanks GM,
Everytime I've said that parallel was better, people have told be I didn't know what I'm talking about. Now I have some ammo.
Back to the topic. I don't think either Nubz or myself want to use up any power with series resistance, since we don't have any to spare. If I decided to monoblock 2 of my amps, then I like the idea of Dave's bipole TQWP, but that's down the road. If I go OB, then I'll add helper woofers. A BR with an F3 in the 100hz range is just not acceptable, but a -3db at 40hz and -6db at 30hz that the TQWP showed me seems much more palatable. I want to leave BSC out of the equation for now other than to substantially widen the baffle at the driver level and maximise the kit drivers' potential on it's own merits without any correction circuitry and add bass drivers later, if necessary.
Sorry Nubz,
I've decided to give mine a full shot on OB, but I have to do my office conversion first next month while the wife and kids are out of town for 6 weeks. I may never get around to building a box for them, but if I do try the TQWP I'll let you know the results.
On OB they sound like all drivers do once you get them out of the box, more open and natural. I'm going to fill in the bottom with the 10" woofers that I'm using with my FE206's, but I'll need to start the roll off of the woofers a little lower because the Parkers are a bit fuller on their own due to the slightly higher Q. I can't finalize everything until I have my new room ready. I'm going to flatten 2 sides of the tweeters' mounting plates to better match the woofers and enable closer mounting. Hopefully that will help the sound blend into a single wave front at 9ft or so, my new listening distance. They won't work in my current nearfield setup because of that issue.
I thought about trying something like the basszilla with the parker audio drivers on top but my problem is that I have a very small room. Mabey one day I will try it with a 10" sub section.
Anyone with a horn modeling program willing to try and see what happens if you put these drivers in a backloaded horn in the same MTM config?
- Could someone model these drivers for me?
