Could someone help me out and convert this .lay to gerber
Sadly yep it is. About 255mm by 90mm or so (from memory!).
It's been a suprisingly frustrating process to bootstrap up to making PCBs at home. The printer I bought turned out to be the main issue - apparently the worst for toner transfer.
Hi Jan, I did try to get in touch, via email and here, to no joy. In fairness, quasi has made available the .Lay and a PDF of the tracks, so I do have all I need to do the job; I'm merely held back by my own basic lack of skill/tools.
Hi jazbo, I actually did do exactly that, with some press and peel paper and a USB stick, and eventually gave up trying to get it done there after a number of failed attempts. :/ I'm back at work as of today, so I'll try using the printer there, but quite frankly, I've now burnt more time on this pcb than makes any sort of sense.
Hence the 'send it to a fab' idea basically! It's turning out to be a lot of diy time spent justifying the pile of 2n3773's I have here. 🙂
