Could anyone shed any light on this amp for me?
Half of 6AS7 works very good with 2,5 kohm in my SE with cool bass. The same I can tell for PSE - Decreasing the output power with small Ri compensate mode PSE. This OT is small for EL34 in triod/penthod mode, IMO, sound will be sharp with small bass. Your output tubes must have Ri about 500 ohms,IMO. I doubt about KT88, 100. Maybe try KT120-150 with output power 8-10- 15 Wts per channel, OT has big iron, I like it.
PT and OTs are very suitable also for 2A3, 300B, 6S4S /6BG4/ with cool and amazing sound, for a level higher EL34. Ra OTs - 2.5 kohm is small for EL34, be sure....If You want use only EL34, You can connect 5-8 ohm/5 Wt resistor in series to Your speakers to "lift" Ra OTs to 3-4 kohms, but output power wil decrease about 20-30 %. Sound will be suitable for hearing.
