Can someone be kind enough to guide me as to
what is the correct way to connect an electrolytic capacitor across a Zener diode?
Do I connect the +ve of cap to ANODE OF ZENER & -ve or cap to CATHODE OF ZENER
OR
Vice Versa??
Thanks in advance!
OR
Vice Versa??
Thanks in advance!
Hi arupg,
A zener will develop a positive potential from its anode (neg) to its cathode (pos). They are designed to break down in reverse. Just like a regular diode except that the breakdown is undefined in the case of the standard diode. 😉
When you reverse the applied voltage, the highest potential you will attain is one diode drop, and most capacitors can tolerate that just fine.
-Chris
No, you don't want to do that.Do I connect the +ve of cap to ANODE OF ZENER & -ve or cap to CATHODE OF ZENER
Much better.Vice Versa??
-Chris
