I want to build an EL84 Ultralinear PushPull amp , i have a couple of power transformers .
One is 240V ac secondary , meaning about 330Vdc at idle , 320Vdc under load , a bit low voltage i think , and is a 300VA rated transformer so a little too big for this application.
The other transformer comes with tap at 290 and 310Vac secondary , meaning 400-420Vdc , is this too high ? Transformer should be a 100VA , so i think is enough.
Sorry for my bad english ,
