Please, I am a zombie with search-specify
, what is approximately the value of Young module for Corian ?
10? 20? I have no idea..... 😕
Very thanks
Paolo
Very thanks
Paolo
thanks, Pete 🙂
Property Typical Result Test
Tensile Strength 6,000 psi ASTM D 638
Tensile Modulus 1.5 x 10-6 psi ASTM D 638
Tensile Elongation 0.4% min. ASTM D 638
Flexural Strength 10,000 psi ASTM D 790
Flexural Modulus 1.2 x 10-6 psi ASTM D 790
Hardness >85 Rockwell “M”
Scale
ASTM D 785
56 Barcol Impressor
Thus,
E= 1.5 x 10 -6 psi ? 😕 too "little".. where is my error?
I have issue also with conversion psi to GPa , oh my God!
Paolo
Scale
ASTM D 785
56 Barcol Impressor
Thus,
Paolo
You are correct. I didn't even consider the number, but that is way too low. It might be a typo and they mean 10E6 not 10E-6. 1.5 x 10E6 is typical value for wood and converts to ~10 GPa.
pete
pete
Thanks Pete 🙂 ,
Ouch! Only 9 GPa....
I was hoping better....
A friend of mine has this strange idea to make a cabinet of corian.
But I have to design it, of course ! 🙄
The only consolation maybe can be the intrinsic damping, but I am not sure of it...😕 Is it so good as "rumors"says ?
Paolo
Paolo
inertial said:Thanks Pete 🙂 ,
Ouch! Only 9 GPa....![]()
I was hoping better....![]()
Paolo
Can't help you with mechanical properties but one builder of my NaO AEP system used Corian for the baffle and he claimed it was acoustically very dead.
Oh thanks Dr. Krekowsky 🙂 ,
For sure they are very beautiful, first!😉
Thus, based on the claim of your builder, is possible imagine that the damping be higher than MDF .... a good thing !😎
Paolo
Paolo
inertial said:Oh thanks Dr. Krekowsky 🙂 ,
Paolo
I can not say for sure, but I would assume so. As I recall he used 2 1/2" sheets bonded together for the main baffle and some edge pieces to further thicken the baffle around the edges so that the black metal baffle support would not be visible from the side.
Thanks for comments Dr. Krekowsky,
This Corian start to become interesting to my eyes (my boxes will be little so the prices I hope will be not-outrageous ! 😀 )
O.T: Seems to remember me you had said in the past , you wanted experimentate also Dr. Geddes Nathans speakers kit ( I hope to remember correct ).......any news ? IMO it would be very very interesting 🙄
Paolo
Paolo
My original Summas used a Corian like material as the baffle. It was mostly just very heavy, but of coarse "heavy" is the bulk of the problem. If you don't want "heavy" then a skin of Carbon fiber backed with a dense polyurethane foam is the best that I have found. But alas, too expensive. In the end you get back to MDF, which is the ideal balance of weight, damping, and (mostly) cost! Its very hard to beat.
gedlee said:e end you get back to MDF
It does burn nice in a hot fire. I gave up on it as a speaker building material some time ago.
dave
Yes, I agree, Dr. Geddes.gedlee said:My original Summas used a Corian like material as the baffle. It was mostly just very heavy, but of coarse "heavy" is the bulk of the problem.
But at least you have beautiful visual effect without paint and use same tools as wood, if I have well understood 😀
If you don't want "heavy" then a skin of Carbon fiber backed with a dense polyurethane foam is the best that I have found. But alas, too expensive. [/B]
Can't be more in agree !
In the end you get back to MDF, which is the ideal balance of weight, damping, and (mostly) cost! Its very hard to beat. [/B]
So it is...... MDF is ideal for DIYers and square boxes.
BTW, I have read from some places that MDF of today is a bit less dense than 10-15 years ago ( here in Italy). Sort of LDF , thus ......
This is good IMO because you can increase thickness and obtain much more stiffness,no? 😎
Thanks,
Paolo
Does a material's modulus of elasticity equate to its damping abiltity in a speaker cabinet? If so, Corian's modulus is almost 3 times higher than MDF. I'd expect MDF to have much better damping.
pete
pete
Nope, Young's Modulus (or the elastic modulus) only relates to how hard a material is to stretch- it directly correlates with speed of sound in the material, not the damping.
planet10 said:
It (MDF) does burn nice in a hot fire. I gave up on it as a speaker building material some time ago.
In favour of ..........?
For the folllowing technical/practical reasons ...........?
widman said:So then what material property correlates with damping?
Damping is a seperate parameter which is seldom if ever given. Its not a standard spec by any means. In detail, the Young's Modulus is complex by a small amount. This represents the damping.
tnargs said:In favour of ..........?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=98834
dave
I'm not sure I understand what you are saying. Can you please clarify this?
Pete
- Corian young modulus ?
