CorelDRAW stopped working
Hi All,
Today I tried to open .cdr extension file and got a 'CorelDRAW stopped working' box appear.
Re-booted the computer and still getting the same error
CorelDRAW has been working fine since I began to use it 2 month ago......
I'm running windows 10
Any help appreciated
Welcome to diyAudio 🙂
If you can't come up with a fix then try here:
https://www.tenforums.com/
What build of W10 are you running ? Currently it should be Version 1703, Build 15063.483
Perhaps one of the latest updates have caused a compatibility issue. Maybe check your installed updates and see if the problem coincides with any.
