Hi All,
Today I tried to open .cdr extension file and got a 'CorelDRAW stopped working' box appear.
Re-booted the computer and still getting the same error
CorelDRAW has been working fine since I began to use it 2 month ago......
I'm running windows 10
Any help appreciated
Welcome to diyAudio 🙂
If you can't come up with a fix then try here:
https://www.tenforums.com/
What build of W10 are you running ? Currently it should be Version 1703, Build 15063.483
Perhaps one of the latest updates have caused a compatibility issue. Maybe check your installed updates and see if the problem coincides with any.
There are many ways to open CorelDRAW file...Just try Googleling and you will find, for example: https://www.viewertool.com/cdrviewer.html
