Re: MC PREAMP.
Mm, but then they could not have written "shielded internal signal
cables" in the ad. 🙂
fdegrove said:Hi,
From what I saw on the pics they could have rearranged the layout in such a way that the RCA in- and output could be soldered straight to the PCB.
Just my two eurocents,😉
I really like the picture where the power supply caps are seemingly sleeping on a little pillow tired after being mounted tilted in a too low clearing height. The connectors come in at the far end and the power cables have to be pulled from the input connector side along the underside of the power supply and up to the transformer. A perfect way of having the AC lines from the power supply close to the tracks...
Elso,
Now, it wouldn't be prudent to have naked men on the picture would it? As for the ladies I think they are probably originally from Scandinavia so cold is just when you're sneezing and nothing else for them...
/UrSv
Elso,
/UrSv
Ordo Templi Orientis
This stuff is all occult including the involvement of Aleister Crowley.
Definitely not for me,
Fred
Fred
UrSv,
i have
at your pix. But i did not see enough 😀
However, i ought to put you in sin bin jut for bad taste
i have
But the question remains: why is the company called Coph Nia?
I suppose it is not named after a band, and they probably do
not want to be associated with the picture UrSv found either,
or is is just my inability to understand marketing? 🙂
Re: NAMING
Of course, I have done that, no answer yet, don't think I ever will.
No and then I ask manufactures/designers and surprisingly they answer most of the times!
fdegrove said:Why not send them an e-mail?
Christer said:
it and didn't like it?? There seems to be a number of
commercial designs using AD797, but I haven't heard of one
using either of the LT amps,
Two then:
-the cheap Trigon Vanguard uses an LT1028 at
the front, and 5534 at the back.
-the MkI Michell/Trichord Delphini and Delphini Mono used the LT1028 at the input. The MkIIs use a different chip.
From my limited experience with these it seems that the 1028 simply adores low-output MCs at its input.
- Analogue Source
- Coph Nia MC Amp from Sweden
