Does anyone know where I can find some cheap/decent ac fans (running off uk mains or 36V) for cooling purposes.
I will be using 2-3 of them to keep good airflow through the case I am building. I am using a 400W bulb so the heat produced will need to be well maintained.
I bought an OHP and stripped the lighting and fan from it. The only problem with the fan is that it is rather bulky.
Here is a link to a picture of the fan (Alcatel QLN65-1800):
http://www.hearthtools.com/98900755A.jpg
Here are more specifics regarding the fan:
http://www.medibix.com/Productimages/38868/Enhanced/qln65dc_files/image001.gif
Should I use this fan as cooling within my design? Is it any good?
I could use it, the only problem I feel is the size of the fan will make the enclosure slightly bigger than I was planning.
Thanks for your time
