I had an Eico HF-81... fully restored it and it was like-new condition after restoring and I sold it contrary to my wish (caught between a rock and a hard friend)!! ... It's been some months and now the buyer (my friend) has blown the amp away so bad I can't fix it using 45 pages of assemble manual and I have no time to reassemble it from the beginning ... many of caps and resistors are blown... some wires are melted!! I took the amp back for a 100$ as is... I think the only parts usable are Choke (tested Ok) , OPTs (tested OK) and El84 and 12AX7s... phono stage tubes are gone... the chassis is fine of course
Now I want to convert it to a simple PP EL84 amplifier, no phono/mic/fm/am/tone control/balance no nothing... just a nice PP project using Mullard tubes and OPTs with a single RCA input... an Alps pot will be used I want your opinion on the schema
disappointed!You can try the Pilot 232 circuit, just use the amp section and keep the power supply from the Eico.
Oh thanks for reply finally
you know, device is malfunctioning and I can't separate PSU from Eico...
Forgive me for saying this, but I think that you have unrealistic expectations. Almost everyone on this forum has a life somewhere else that takes most of their time. Many will only look into the forum once a day, and often rather less. Of those who had viewed your thread, I would think that most would not know what an Eico HF-81 amplifier is and so they would not reply (I certainly have never heard of that model). To express disappointment at a lack of response after only 5 hours from your original post seems completely unnecessary.An externally hosted image should be here but it was not working when we last tested it.disappointed!
The HF-81 is probably the most talked about EL84 integrated amp in recent years, at least in the USA. Since the 2006 write up in Stereophile, its price has skyrocketed for a low powered integrated amp. It also inspired many DIYers to modify this gem in various websites. Some audiophiles are excited about it and some are disappointed. I heard one and it sounded good but I think there are many sleepers out there just as good or better. Regardless of one's opinion about its sound, it is certainly the most talked about amp of its genre.
I do understand your point about the OP not being patient enough and I agree.
Okay then, just build it like the circuit and use whatever existing parts you can salvage from the Eico. If you plan to use the Eico chassis then you can't use an octal tube like 5AR4 without drilling a bigger hole for its socket. I would just add a filament transformer so you can re-use the dual EZ81/6CA4 rectifier tubes.
Here's the schematic for the HF-81 and you will notice the Pilot amp section uses the same tube complement as the EICO so it's not that hard to implement the circuit. The Pilot is the best sounding 6BQ5 amp I have ever heard, period.
There are lots of EL84 circuits out there. SY's Red Light District, some from TubeCad, the Baby Huey, El Cheapo, mine:
http://www.diyaudio.com/forums/tubes-valves/213947-just-what-world-needs-another-el84-amp.html
Lots of different ways to implement this depending on your taste. Even though the designer of the Simple EL84 is a poster on this forum, he doesn't frequent the tubes section from what I can tell. According to his website, he's moved on to class-D amps. You might be able to find him posting in the analog line level section as well.
The HF81 amplifier section is about the simplest you can create. PP EL84 amps with concertina splitter/driver sections don't sound bad, so why look for a different schem?
jeff
SY's Red Light District, the Baby Huey, El Cheapo
I consider these the 3 usual candidates. We have an El Cheapo variant with triode strapped EL84 (no feedback) that is VERY good. If you want more power, Baby Huey adds RH-style Schade feedback. I like the LTP front end.
dave
Agreed! Why need to reinvent the wheel?
... why not something like Tubelabs Simple P-P with 12AT7 in front (input gain stage - concertina). Enough gain to use also gFB as George does in pentode EL84 configuration ...
Maybe regulate the EL84 screen supply?
Eico HF-81 schema is so complicated with lots of In/out terminals...
Just disconnect/bypass all the stuff you don't want.
I just want to make it easy... I know transformers of Eico HF-81 are magical so I used them to build a new amp... all tubes are original (Mullard) I'll use them
I don't see how building a whole new amp is easier?
jeff
jeff
How to bypass tone control? balance? input selector?
You can try this, easiest and only amp section and keeping the volume control:
If you want to include part of the line stage, which I think it's where the "magic" is and more gain. Purists will disagree but you can always compare the two.
Anyway, I don't see how other EL84 circuits can be simpler....
Another option is to simply copy the HF-86, which is essentially the pure amp version of the HF-86. The driver, however, uses the 7247/12DW7, which is half 12AX7 half 12AU7. You can see the similarity between the two.
- More Vendors...
- Tubelab
- Converting Eico HF-81 to a simple PP EL84 (pics incl.)
