Does anyone know of a mod, what parts would be needed or how you could convert a PAS3 to a PAS3x with tone controls that are out of the circcuit when centered? Or... possibly the instructions/schematic for adding a switch that would simply bypass the tone controls when not needed?
Thanks in advance.
Thanks in advance.
The PAS-3X used special mono pots that either had an open circuit in the middle (treble), or else had two wipers (bass).Does anyone know of a mod, what parts would be needed or how you could convert a PAS3 to a PAS3x with tone controls that are out of the circuit when centered? Or... possibly the instructions/schematic for adding a switch that would simply bypass the tone controls when not needed?
However, the entire PAS-3 tone circuit can easily be permanently removed.
See http://www.audioregenesis.com/ for a well respected author.
Also, another difference is that PAS3X has a cap in series with the output which isolates a small DC from the output signal.
