Conversion Lens: possible usabilty?
I will be testing one out in a few weeks. The prolblem is finding one that will cover a 62mm lens. The one I found is for a beta cam. There was only one of them with shipping it will be $50 . The CANON C-8 TELE CONVERTER 1.4 X 67 might work but someone has to try it out and they are rare too. most are made for 52mm or smaler lens. good luck.
Right now my test setup is just a 60 watt light bulb. I saw someone on ebay use one for finding the FL. the test rig will be done in a few days. The qualityof the teleconverter is great and the throw looks like about 1.8 X the rear FL of the triplet got longer by about 60mm but this lens is a one of a kind the only other one I could find with the same speks was made by canon and was $450. I think by looking at this one it probulaly cost that much it is about two pounds and looks real expencive there was only one on ebay. I was hopping to find a cheep fix that everyone could use.
There is one that is made for the canon XL and it is $109 new but I bet that the rear clear is even less than 58mm. someone would have to try it. It is a hard call when the pro lens from LL should be out in about 3 or 4 months and the 135mm from DIY PJ is $119 then there is the Opaque Projector that can be had for around $100 I bough one and have the lens it is almost 5" in dia but it won't focus sharp on larger than a 15" LCD
