Well I have a set of dual 15 inch 450w RMS FOH loudspeakers equipped with 400w Compression horn drivers. The problem is, the 15 inch drivers and the horns have been designed to be amplified seperately so there is no passive crossover built in just 2 seperate binding post connectors for Hi and Low input. They work beatifully with this setup with an active crossover however Im about to upgrade the amps and go to Speakon Connectivity.
My problem is that when I install the Speakon inputs and wire to the two 15" drivers and the horn, it will also conduct current to the 2 other terminals and ruin that existing 2 way setup. I am wondering If it could be possible to use a diode in the existing wiring to keep the signal going 1 way? Cheers
