Construction: The best way to cut a hole for an IEC power inlet into sheet metal
There are little jobbies for a jigsaw ..like a file..
1. ) Draw the socket on the metal,
2.) drill the biggest hole that "fits"
3.) file out the rest.
I have never done this..AND apparently you need an adapter for the jigsaw that is relatively expensive...however this should be quite a universal little tool.....
Bas
I usually find that rotary tools are the best for this type of job. So for the last 200 or so holes I did in sheet metal, I used an high speed air powered tool with a carbide bit. I guess a regular dremel or a similar tool with a tiny file would work too!
Hope this helps!
Sébastien
A drill, a hand nibbler, a few files, and a bit of patience.
These gadgets usually cost around $10.
I always use a 10mm drill to make two holes at opposite corners for a jigsaw blade to fit through. Four simple cuts with the jigsaw and then file to the line. It's not my favourite job but it's actually very easy. Adequate jigsaws can be picked up for only £10 new in the UK.
Well,
As it turns out, I might not have to do anything. I am working with Par-Metal and am trying to get a chassis made for my integrated amplifier, active XO, DAC and PSU so that I can have it all in one box.
If need be, I have files, drill, tin snips, and a dremmel, but it hasnt been used in forever and I dont know what bits I have.
-Paul Hilgeman
You have pretty much everything you need to do hand-work on your front panel, should you decide not to go with Par-Metal. You may need to get some new bits for the Dremel, they may not be cheap but they are not expensive and save a lot of time. Look for a rotary file or other metal cutting bit. As an option, look into getting the smaller jewellers files for finishing anything small.
🙂ensen.
