How good is the bond between the two wood materials with the BONDZ paint? Can you pry them apart by hand, and have you enough time to see if the bond degrades over time (may not matter using the right construction technique, just curious).
The BONDZ primer is basically glue, the surface of the wood would come off before the paint failed. So... no, you cannot pry them apart by hand.
