Constant Current LED Driver for Pass F4/5/6 etc
A constant cap multiplier using a mosfet will lower the voltage by around 4V, then you are at +-26V. But each multiplier will dissipate around 12 watts, or if you go for a multiplier per rail and channel, 6W each. Yes, you will get rid of some low frequency nastiness in the process. You probably need som caps after the multiplier to act as a local reserve, let say at least 10mF per rail and channel, four caps in total.
It's certainly cheap enough, but appears out of stock?
You could also use a ~0.4R power resistor or suitable inductor in a CRC or CLC to knock down a couple of volts too. But those Pass DIY amps are not fussy about the exact voltage, so even +/-30V is fine here.
