I bought a soft start from Connex a while back. He has a link to the tech document on his page but it doesn't state the wiring of the product. It just has it labeled as "Load 1" "Load 2" "Main 1" and "Main 2". What is the proper wiring for this?
http://www.connexelectronic.com/documents/Power_SoftStart.pdf
The "Mains" pins are connected to the mains .
The "Load" pins are connected to the primary side of your transformer .
Connect a single pole switch between pin 1 and 2 of connector J2 to switch the amp on and off .
exactly as described in the document you attached :
Cheers ,
Rens
