Connecting Two amp to a transformer
Hi there
I have made two of this amp and I want to connect them to a transformer
230W / 400W Mosfet Amplifier
Is there any way so I can just use 1 transformer for both of them??(Like Stereo) 😕
I heard that because of its symmetrical supply I should use each one with a separate transformer????🙁🙁🙁
Symmetrical supply is used in most of the stereo amps and are invariably powered by one transformer. There is no difference in stereo and two amplifiers. Stereo is a two channel amplification of stereo recorded material and is always two amps electrically but are never called so.
You should see that you have enough VA rating for the transformer.
If you have to place these two amps far apart, then the issue is little different.
Gajanan Phadte
I think that our conversation got a wrong turn possibly because I caused that, I am here to offer a quick tip, and not to offer knowledge coming from schools and long term education.
My suggestion would be to study for a year the theory of switching power supply, and in time you will understand what tools you do need by your self.
I am in the smps biz since about 20 years, and looking back I can say, that delivering a circuit diagram will not help a newbie to build his own smps. There is much more around that to be considered, specially safety issues.
There are things I will never put my hands on, simply because I know I am incompetent in many fields of life. For instance repairing any gas driven equipment...
A noob building offline smps is another variety😉
To be honest I did sensed that our friend here needs dramatically to cut down cost by removing the Iron core transformer from his equation.
smps is a world of pulses, IC's and capacitors with specific properties, inrush current calculations, and more in depth knowledge of electronics engineering is required.
It is best for him to follow the simple steps of which he has their basic understanding today.
No all projects comes out perfect by the first attempt, but if learning is not what you seek? The buy a commercial amplifier and enjoy the music.
Thank you for all your answers
You're right
I have to study more about this field
But I just want to know my required equipment for designing such circuits, so I can buy them gradually untill then
An SMPS is the last thing you will know to design after learning to design all the different circuits. One critical design flaw and eveything will go into smoke. It should also stand to the test of the application and when audio is concerned, just any design may not sound good.
Gajanan Phadte
Edit: any design will definitely need an oscilloscope. To begin with, for initial learning, an 100MHz dual channel will be fine.
Gajanan Phadte
Thanks for your tip
I won't make one unless I now exactly how it works
beside when I obtain the knowledge, I do not have to start designing a 220v power supply
I can start with low voltage converter like 12 to 24 or so
Right??
And after couple of circuit like that I will go for 220 circuits
High Power SMPS design is indeed an art and experience in this field is vital, many attempts by newbies will undoubtedly end in failure.
However, do not let that stop you delving into SMPS experimentation.
A simple place to start is with the TL494 or SG3525 datasheets. If you keep to trying to illuminate say a 240V lamp from a 12V battery you will learn how the basic concept works.
