connecting i2s to dsp enhanced serial audio interface
Hi I am taking my brave first step to the digital domain in diyaudio starting from dsp chips.
Becasue the terms are used differently, I would need some advise on the correct connections on the respective i2s pins (MCLK, LRCK, SCLK, SDATA) to the dsp56362 under the default enhanced serial audio interface mode.
So after some reader I cam to the following conlculsion (--- mean connection)
1. MCLK --- HCKR
2. LRCK --- FSR
3. SCLR --- SCKR
4. sdata --- SDI0, serial data 0 ( this make me scratch my head, there are 4 serial data port, how does the dsp recognise serial data 0 it outputing the correcting signal not the others ports)
For your dsp pdf page 23
Blocked
thanks in advance
