Hi everyone,
I want to use headphones with my guitar amp (head not combo), but there's no headphone socket. From research I've done so far, I understand I probably can't plug the headphones directly into the speaker output. Can anyone please advise on what I need to do?
First question - what type of amplifier is it?
If it is has a valve output stage, then you will need to dummy load the output, which is fairly inconvenient.
If it is a transistor amp, then no problem - a suitable resistive divider might consist of a 100 ohm resistor in series, wired from the output to the commoned tip and ring of the headphone jack socket, with a 10 ohm resistor in parallel (from common tip and ring to the sleeve). The sleeve connects back to the amp.
2 watt rated resistors ought to be fine - unless you want to play REALLY loudly....!
Thanks both for your replies.
The amp in question is an Ashdown MAG300H. Its technical spec is here: http://www.ashdownmusic.com/bass/detail.asp?ID=112. I believe it is all-transistor. The minimum output loading is 4 ohms.
John, I'm afraid I'm being somewhat dim but I'm finding it hard to form a clear mental picture of the scheme you're suggesting & I don't want to run the risk of messing-up. Would it be possible to post a simple sketch, please?
Mike
Mike
Can't send you a PM - so you will have to e-mail me via my Web site:
www.orchid-electronics.co.uk
JG
JG
http://www.vk2zay.net/calculators/simpleDivider.phpmike6182 said:Thanks both for your replies.
Mike
From John's suggestions, R1=100, R2=10, Rsource=0, Rload=headphones, Vin is amp output, +=positive, -=negative
- Live Sound
- Instruments and Amps
- Connecting headphones to guitar amp speaker output
