Connecting Groundzero Sub to amplifier
I have a Ground Zero 900Wrms sub, is it possible to connect to a Kenwood KRF-V7030D Amplifier to speaker B channel (100Wrms x2 4Ohm)?
If yes, how can i make a filter so that it only gets the Low tones?
I`m sorry if it`s been in the forum, i searched but i couldnt find anything cause i dont know what to look for exactly.
Maddog....the sub should have a coil on it...or are you talking about having just the driver....your kenwood amp will blow up if you connect speakers on A outputs and the sub on B outputs (impedance will overdrive the amp).....purchace or build a amplifier and drive the amp off the tape out or any output on your amp
DIRT®
