I'm new to this forum and i have a question regarding Power Supply Design.
I try to build a converter, and i want to use IR2112 to connect PWM to MOSFET. Can someone show me in diagram ?
Appreciate and expecting any suggestions. Thanks.
I dug up an early design and changed the gate drive to my latest preferred way.
One thing I have remembered is that you will most likely need a snubber circuit connecting from the MOSFET totem pole midpoint where the source of the upper one connects to the drain of the lower one. The other end of the snubber connects to one of the primary side electrolytic filter capacitor nodes.
