Confusion about a 5Y3GT rectifier
however if you base your knowledge off physics then you'll understand.
If you are referring to separate heater and B+ transformers, then the only 'physics' aspect imho is if the heater windings are being pummelled for a DC heater supply, or if the B+ supply is grossly distorting the AC heater winding voltage - is that what you meant, or is there some other physics issue you are alluding to.
