Just ordered the Elekit TU-8600S. I want to order the cap upgrade next, but not sure which is the correct value. I did some reading here but it seems either .1 uf or .22uf is used for the TU-8600. Is one the correct value and the other a preferred value? Looking at the V-cap ODAM capacitors, just don't know the correct value. Any help appreciated. Thanks 😀
Do the caps need to match? Some offer capacitor matching service, within 5%, 2%, 1%. Not sure if it’s needed.
Thanks, did you get matching capacitors? Some online shops offer it. I don’t understand what the purpose of it is. I can see why matched tubes would benefit a push-pull amp. Not so sure what the purpose of matching capacitors is or if needed.
I built the 8600S recently, started out with the Mundorf and later upgraded to the V-Cap CuTF. They were both .1 uf. I bought everything from Victor and the V-Caps came matched. I don't know why and didn't ask, I just installed them that way.
I'm curious to know if matching capacitors is necessary for the TU-8600. Matching to within 0.5% will cost an additional $48 for 4 caps. No matching is no charge. I would hate to pay $48 for something that isn't needed, lol. If someone has the answer please let us know. If you buy caps off V-cap's website, they offer capacitor matching.
TU-8600S uses 0.1uf.
0.22uf is for older series of TU-8600. I used to have the TU-8600E and it used 0.22uf.
I bought my CuTF V-cap from Victor together with my TU-8600S.
2% matched should be ok. That's how Victor match his vcap as well.
I also got CuTFt caps with the 8600S kit from Victor and I recall some writing on
the caps, presumably measured values. They seem pretty close from what I remember.
