Concrete speaker stands
You could try the mix for counter tops. You could use melamine and mold release wax. Your surface will be smoother and you can finish it. A little research on concrete counter tops might steer you in the right direction for your project.
I do not know the precise mix but adding some PVA is a good idea. Either PVA designed for cement mixes or just ordinary woodworkers PVA glue.
I am thinking about making some concrete blocks for my Celestion SL6 speakers. I am planning on making 3 inch thick slabs and standing the slabs one on top of the other - this will make moving the stands easier. I have thought out the mould - I am going to use MDF and planed pine. I am going to use model aircraft wing covering which is waterproof to seal the wood surfaces. A common brand is Solarfilm.
