Compression drivers - Radian 745be - B&C DCM50
I'VE GOT TOO MANY COMPRESSION DRIVERS!
1 pair Radian 745neopb-8. These have the expensive Beryllium diaphragms. These are listed at £1327 each. I will accept £1200 for the pair.
1 pair B&C DCM50-8 - £400
Please note. So as to measure the exit angles I've removed the bug screen from one of the drivers in each pair. (I've been careful to keep a small piece of foam in place so no debris could enter)
These are located in the UK.
