Componment placement
What I see is that the front stage is comparable, but the output stages are adapted to their use, a symaym2sym or hp amp.
If it disappoints however, I'll send you a simple stable 12Q-18R-2C symasym2sym circuit draft I've developed recently. Any ps is good, no adjustments, only 4 good ≤1%resistors needed, rest is indifferent.
12 transistors (denoted as Q#), 18 resistors (ditto R#), 2 capacitors (''C#), all to the bare needed minimum. Shortings on the compatitive league are my grounds <-> shortings on the compatitive grounds are my league. {Is this or which of this is english language proper?}
