component magnetic field interactions
Hi all,
My equipment cabinet interior is 21" wide, 16" tall and, 15" deep . It has a fixed bottom shelf and two height adjustable shelves above the bottom shelf.
The amp is on the bottom, preamp about 2" above it and CD player about
1 1/2" above the preamp. The preamp has an isolated power supply, that is outside of the cabinet, but I think it might be good to shield it from the amp and CDP.
I'm concerned that the components, being so close, could cause some interaction related to their power supplies. I've read about Mumetal but have also read some shielding material can make a magnetic field bounce back to the component from which it emanates. What is the best way, in my setup, to shield the components from each other?
I was also thinking an open ended box put over the amp's transformer might be a good way to shield the preamp from the amp. It would also shield other components in the amp from it.
Thanks,
henrylrjr
The system sounds quite good. Jack Dejohnette's wood sticks on cymbals sounds very real and the trumpet opening in Mahler's 5th also sounds very good.
However, when I put my ear within about 2" of the drivers I hear a very slight hum. I just thought shielding might remove that and make the speakers dead quiet.
Since shieldiing material is rather inexpensive l thought it would be worth trying. I'm looking for some recommendations instead of buying and trying a bunch of different stuff.
Thanks,
henrylrjr
............However, when I put my ear within about 2" of the drivers I hear a very slight hum...........
A measurement is far better in helping us to help you than using your ears.
Set your DMM to 199.9mVac and measure the output noise.
Since you mention hearing hum and not white noise, I'd guess that most of your measurement will be hum.
Is it 0.1mVac, or 0.3mVac, or 1mVac?
1mVac of hum is ~-79dBW ref 1W, 2.828Vac into 8ohms.
A 90dB speaker would be outputting ~11dB @ 1m, which is pretty quiet, but audible at 100mm
a look at the waveform/spectrum is helpful too - even a free PC audio based SW Oscilloscope/Spectrum analyzer would be fine
its useful to make the distinction between "hum" and "buzz"
with "hum" reserved for mains power frequency by itself - which can be power xfmr field coupling or chassis leakage current ground loops
and "buzz" being the rectified power line harmonics - more likely internal wiring common impedance, although coupling to rectified current carrying wiring loops can be by magnetic induction too
