Ok, I built a guitar cab and have run into a problem, I need some opinions on how to tune the bass part of the cab. I made it completely sealed and with two compartments inside, top for highs, bottom for lows.
The speakers resonance frequency is 48hz so I would like to aim for that if possible (and unless it will muddy up the sound too much)
Here are some pics of the cab, you'll see what i'm talking about
Image hosting, free photo sharing & video sharing at Photobucket
The bass is way too quiet, especially since the Man O' Wars have a 5db higher SPL. So I want to port it. The only spots are in between the speakers, in the middle vertical of each other as you can see. I can fit a 3" diameter port on top and bottom, and if I had to I could squeeze in a 2" diameter in the bottom left and right, or some kind of combo of them all.
The internal dimensions of the box are 13⅜"h x 28½"w x 11⅜" deep = a volume of 2.5 ft^3
The bracing is ¾" h x 1½" w and has a total length of 106" = a volume of .069 ft^3
So the volume of the box would be 2.431 ft^3
I need to know how I would calculate the volume of the 1½" foam, the inductor, and the front loaded drivers (baffle wood is ¾" thick)
Here are the specs of the drivers:
http://eminence.com/bassguitar_speak...2&SUB_CAT_ID=5
There are two drivers (obviously) so the port will have to be tuned for 300w.
I know it's a lot of stuff to comprehend, but that's why I'm here on DIY Audio.
Just tell me if I forgot to post some information, or have any comments on the cab too.
Best thing would be to reference your drivers and post new/better links because those don't seem to work.
Is this a bass guitar? If not surely you don't need tuning down to that frequency. Most of the guitar cabs I have come across are either sealed or open back, with the sealed giving slightly more weight to the sound.
UPDATED
Ok, I built a guitar cab and have run into a problem, I need some opinions on how to tune the bass part of the cab. I made it completely sealed and with two compartments inside, top for highs, bottom for lows. Crossed over at 330hz
Pictures by andrew-skaterrr - Photobucket
Eminence - The Art and Science of Sound
The main question is: How do I calculate the volume of the foam, inductor? (I think I know how to do the front loaded drivers.)
I wanted to make a metal guitar cab that could handle the low tunings. Most guitar speakers drop off around 75hz. Also I can use it as a bass cab when my bassist comes over. He loves the sound he gets.
The volume added by having front loaded speakers is .0941 ft^ so internal volume = 2.5251 ft^3
then I measured and think I have the inductor volume: .0039 ft^3 = 2.5212ft^3 total.
foam volume = .3745 ft^3 = 2.1467 ft^3
If i round down to take the wire volume into account then I get 2.14 ft^3 as the total volume of my box, now i can calculate the ports
You can put stuffing in the lower half to make it adiabatic
(less temperature change with pressure), behave perhaps
as much as 15% larger inside, some claim 15% anyways...
But don't do that to the MOWs up top. Leave that part of
the cab hard, empty, and reflective inside.
You can port the bottom of the backside... Bass ports
won't care which side they are on, as long as you don't
push the back flat up against a padded studio wall.
Looks like your coils are strung in series (8+8=16 ohms)?
If so, have you accounted for this in your crossover?
so what you're saying is take the foam out of the top and put it in the bottom?
and yes, I have it in series/parallel. drivers are in series, top and bottom are paralleled, i had to do it this way to get a good load and to use my crossovers
I did take the 16ohm load in consideration with the inductor/capacitor
No, I'm talking about polyester pillow stuffing that can breathe, absorb and
release heat as pressure waves travel through it. That makes the cabinet
appear bigger inside, or so the theory goes...
I don't think your eggcrate type foam does much for enlarging an enclosure,
it only deadens the wood. Which is OK in the bass part of the cab, but not
the upper part, unless bass is making the whole cabinet rattle....
ok that's what I thought
I read that acoustic foam helps absorb standing waves, cleaning up the sound, that's why I got it.
Charles's law - Wikipedia, the free encyclopedia
Boyle's law - Wikipedia, the free encyclopedia
The stuffing supposedly soaks up temperature changes.
So you are only fighting one ideal gas law, and not both...
I see what they're talking about.
Well I've done all my calculations, I have a volume of 2ft^3 after I take out speaker displacement, inductor, wood, and foam volume. So I end up needing 2 ports that are 2.75 in dia and 5 in deep.
So now I need to decide if i'm put them in the front or back. I'm afraid that if they're in the back the bass wont be as punchy.
Irrelevant, cause ports don't punch. Cones do.
Your cones is located on the front, yes???
Assuming system is tuned punchy (Q <= 1)...
I mean, you still gotta tune your box not too
mushy for the driver to have punch. But port
placement??? Really nitpicking.
I'd shave an inch off the lower back. And hope
maybe the corner of the wall and floor will give
me a little horn loaded boost.
Keep the cutoff. If you later discover you need
to block off part of the vent. Screw it to the
bottom (on the inside) and abuse to adjust.
Also your circuit might be flipping over phase
around the crossover frequency? I don't know
your crossover circuit, is it more than just a
choke coil?
Tried seeing what happens if you deliberately
miswire woofs out of phase with the MOWs?
Sometimes that fixes phase, sometimes not...
choke coil?
ditch the acoustic foam and the inductor, this is a guitar amp.
If you can't get the sound you need from your AMP controls, this is where the problem lies...
This type of box is a part of a musical instrument and not intended to reproduce sound, look on it as the body and sound hole structure you find in a bass viol.
Bass guitar boxes in general have a 60Hz. punch peak, and you will find the typical bass guitar driver is uptimised for this. In general it is best to design the box for the formant you want, then tweak the tone controls.
Having a steep high pass filter about an octave lower than this is also advisable since bass guitars produce a very large d.c. component that causes a large cone offset, and this can be greatly increased by the technique of damping the strings with the hand.
The effect of this offset is to soak up large amounts of power and produce no more sound.
rcw.
rcw.
rcw.
the whole idea of the cab was to have a biamped/biwired cab.
So put the ports on the back panel towards the edges? And I'll switch the + & - on the basslites and see if that helps
choke coil?
You could try removing just the cap, running the MOW`s fullrange, then you`ll get more bass.
from what I've read, that would give a funky load that the amp would see, you need to have the cap and induc as close to the same frequency as possible
- Live Sound
- Instruments and Amps
- (Complicated) Guitar Cab Tuning Question
