Take a look at this thread too. It discusses the Quicksilver KT88 UL PP amp, which would also be a good one to clone. The schematic posted is for the version using the very rare 8417 tube, but hopefully someone will work out the differences and post them.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=8555&perpage=15&pagenumber=1
FROM 8417 TO KT88/6550
Actually the differences aren't huge and easy to do:
http://www.triodeel.com/8417.htm
You can also implement the modification to the PSU as Joe posted in the Quicksilver thread.
Easy peasy.
Cheers,😉
Easy peasy.
Cheers,😉
Frank and others..
I will make the changes and post the amplifier section of the KT88
mono block Quicksilver amplifier next week as I am off that week and will have the time to do it. This may serve as an interesting topic as well as a good building tool to follow?
As I have nothing to compare the modified power supply to I must admit that I find it very smooth and also an am not hurting for bass response.🙂 🙂 🙂
If I had known the information existed for modifying a 8417 amp I probably would have purchased a used pair off ebay for less than I paid for these KT88 mono's. Either way I am very satisfied with the performance of these amps.
Joe
Joe
KT88 SCHEMATIC
That would be nice,thanks Joe.
Cheers,😉
Cheers,😉
Looking at it again, I'd build the GEC over the Quicksilver, with a couple of minor mods. I'd phase split before the 12AX7s with a Lundahl LL1544A, or similar Jensen trans, make it balanced in, and put a CCS in the tail of the first two stages down to an extra negative supply (-20V?). The last is just my preference for a real diff stage, rather than PP.
Addendum
If someone were to build the QS, a pair of Dyna 431 like those out of the Dyna Mk3 would be good candidates for OPTs.
Tube manuals
There are a few online:
1) Sylvania Tube Manuals (1943,49 and 1959)
http://www.montagar.com/~patj/electro.htm
2) RCA Radiotron Tube Manual, No. R-10 (Tim Reese’s site) http://www.nmr.mgh.harvard.edu/~reese/RC10/
3) RCA HB-3 Tube Manual (Pete Millett’s site) http://www.pmillett.addr.com/hb-3_tube_manual.htm
4) Karl R. Spangenberg, On Vacuum Tubes. (Ken Gilbert’ site) Used by grad students at Stanford studying vacuum tube design in the 40s. http://ken-gilbert.com/spang/spangenberg.html
These are in the outline of online tube info I sent you.
The first 25 pages of tghe R-10 is worth the read while you're waiting for F.
At least you can see what one is.
cheers
Craig Ryder
No, I do not have a tube manual. Where might I acquire such a thing? Do these include schematics?
cheers
Craig Ryder
DIY
What do you all think of the feasibility of a stereo SET putting out about 60W per channel? Or do you think that monoblocs would be better?
I am debating what to do here with making a project. I am eager to get going...
60W is feasable with PSE. Otherwise we're talking "exotics".
Whether monoblock or not makes no difference in performance for a properly designed system. The main reason for 2 chassis' is weight.............But as you're T_Strong...maybe you can manage😀
Tube manuals
Here are a few more online sites for tube data (and let me know if I missed any, OK?)
http://www.audiophool.cjb.net/Techno.htm
PSE means Parallel Single Ended. By paralleling the output valves in an SET amp, it's possible to double or tripple the output power, though all do not approve.
Probably the "Push Pull" topology would be better for a starter amplifier. Easier, and much cheaper to get that power output.
Also, have a good think how much power you actually need.
Check on previous threads abou speaker efficiency vs power.
60W
I stand with D'haen here.
60W in single ended is going to require a lot of paralled tubes.
I'm not even sure there is such a beast out there.
Much easier to do with a simple PP of a pair of output tubes and improve the circuit by paying attention to the power supply (PSU)
and other "details".
Cheers,😉
Cheers,😉
60W DIY
Tom: thank you!
Dhaen, fdegrove: So, it seems that the route to go is the push-pull way, for both simplicity and cost. I was under the impression that P-P led to poorer performance, (as it does in some solid-state amps) but I wonder if I should even worry about that for the time being?
fdegrove: You say that improving the 'details'such as the power supply, would sweeten the experience of the P-P tube amp. What else do you recommend?
Tom: thank you!
FIRST AMP
Generally,paying attention to layout,passive components choice such as coupling caps,resistors,hook-up wire even the solder you use.
Once you've made your choice of amplifier circuit you'll see the advice flowing in from all sides,believe me.😎
Cheers,😉
Cheers,😉
60W DIY
OK! layout of the circuit pieces? and wiring? what would the board recommend?
What are the best brands to use for the caps, and resistors? I am eager to discuss the items on parts list, or what the list is, for that matter?
Well, it's a bone of contention😉I was under the impression that P-P led to poorer performance
Although I am an SET man myself, I'd be the first to admit that a mediocre SET sounds worse than a PP to anybody.
What I was trying to get over (please excuse my limited descriptive powers - after all, this is my native language
Whereas PP (even though the component count may be greater) can achieve super results.
If, on the other hand you want something that sounds soft and warm: sell your speakers, buy some high efficiency ones, and build a 300B amp, and wallow in it - be happy🙂
HANG ON....
Tony,
Hold your horses...
First things first:
1/PP amp 50-60W?Which one,Genalex or more like the Quicksilver?
Or something else perhaps?
There are at least a dozen schematics available on the net for that topology alone.
2/Sources for unusual compontents such as the OPT,choke(s) powerxformer,chassis,tubes etc.
3/After that we can discuss the finer details.
Back to you Tony,😉
Tony,
Hold your horses...
First things first:
Back to you Tony,😉
DIY 60W
I would defer to the best suggestions of the group as to which topology/design to go with: quicksilver or Genalex..
As for sourcing parts, any direction would be appreciated...
- Tubes / Valves
- Completely new to building amplifiers
