Complementary-Symmetry Cascode Amplifier
A complementary symmetry all-cascode power amplifier design with no overall feedback. Local error correction for the output stage which uses low-voltage high-current MOSFETs in a cascode configuration with power darlington bipolars. Simple signal path but with elaborate support circuitry for current sources, etc.
Question: Will the output stage be stable? I never built this design but am curious to know if it would work as planned. I am self-taught with no degree in EE, so please be gentle with comments. Thanks!
Notes:
1) The active current-source load for the input differential pairs was borrowed from a Burr-Brown linear op amp applications book, the purpose of which is to reduce DC drift in the front end and improve common-mode rejection.
2) The idea for the error-correction circuit in the output stage was borrowed from an article (circa 1976 IIRC) in the Journal of the Audio Engineering Society written by a British audio engineer (I can't remember his name) and was described as "feedforward" error correction.
Malcolm Hawksford was his name.
He has written a few papers on error correction. The first one I saw is this one from 1980: https://www.semanticscholar.org/pap...b6b54ba291ea6936ec558080733cbeae#paper-header
This one you can download uses an approach that seems more popular: https://www.researchgate.net/profil...n-switching-power-amplifier-output-stages.pdf
There's been a long (and sometimes rowdy😀) discussion of the approach elsewhere on this site.
Many thanks!
