complementary jfet input trimmer
Because Vgs of the N-ch is different than the P-ch at the same conductance, the pot trims DC output. It would have a small effect on gain symmetry, but the AC current change of the input J-fets will be small, that current change being dependent on what the next stage requires. If the DC voltage on the gates is 0V, the DC output would be the difference between Vgs of the N-ch and P-ch J-fets times Av. Also if the J-fets are not bias at their zero temp co, the DC output may drift a bit with temperature since the change in conductance vs Vgs is unlikely to be equal between N-ch and P-ch devices. A DC servo would perform the same function and not have a pot wiper contact:dodgy: making up the FB loop and cancel any effects of thermal drift. Or you could match 'complementary' J-fets, but good luck with that.
