comparison between volume and power
You need to find out how sensitive your speaker system is.
Build it without an amplifier to start with. I'm at work at the moment so I don't have the exact figures in front of me. Most speakers are quoted at a dB level at 1m when fed with a signal of 2.83V RMS.
So, if you feed it with a signal of 2.83V RMS and get 88 dB of sound, your speaker will have a sensitivity of 88 dB/W at 1m.
Once you have this figure you can then ascertain how much power you need to obtain the volume that you looking for.
I like to add 1 thing here, this only holds true for an 8 Ohm driver. Usually sensitivity is spec'd xdB/W @1m. Important is whether this is into half space or full space. And don't forget to take power compression into consideration.
okay now lets say i have a 18'' sub cabinet that is about 160 litres, what power do i need in this case?
You cannot have too much power 🙂. An amp with more power has better damping factor, so it will sound better even if you don't use all power. A bigger amp will have better power supply, helping out in transients at lower power levels. Also a big amp will not clip. Clipping is very bad for you drivers.
