Just finished "researching" this topic by actually looking back a few years on this forum - and not finding anything. So here are my questions:
1. I've seen reference to common-mode chokes used in the INPUT to transistor power supplies and tube filament/plate supplies. Could someone point me to a good discussion of their use and specification (size, current ratings) in this application AND suggest a type(s) and manufacturers.
2. Cello actually used what I'd call a common mode choke in the OUTPUT of their Performance amp +/- 80volt main power supply. It is an L-C configuration with a giant choke that actually has two windings so I'd say it qualifies as "common-mode" - WHILE is handling AMPERES; like 10 to 15. Has anyone used this technique and can share their experiences?
THANK You
Charles
THANK You
Charles
If it is used in an LC input filter or a pi filter (CLC) it would be a "differential-mode" choke, with the normal supply currents adding up rather than cancelling out as in a common mode choke. It is a means of combining two large separate chokes in an LC or CLC configuration into one. I have no info at hand but I know there is info on this forum and elswhere in the WEB.
We use them for EMC reasons, here some links to theory etc
http://www.butlerwinding.com/inductors/common_mode.html
http://www.murata.com/emc/knowhow/pdfs/te04ea-1/26to28e.pdf
1) Common mode chokes primarily provide a high series reactance between the source and the load in relation to ground. This series reactance or inductance in conjuction with added shunt capacitance to ground forms a 2nd order lowpass filter. The load current as it is increased will reduce the inductance and Q affecting the filter response. Look at the Corcom site for typical fitering (attenuation) charts. http://www.cor.com/Series/IEC/EF/
To be considered a common mode choke the 2 windings have to be balanced. The forward and the return currents must be from the same source yet opposite in phase ie they must cancel each other. Since the flux of the desired signal ie mains frequency cancel the net difference inductance looks very low yet the common mode inductance is high.
Leakage inductance (much lower in relation to common mode) determines the residual filtering in the transverse mode. Leakage inductance is related to how (un)closely coupled the two windings are. Leakage is good in these applications for dual purpose filtering.
Tutorial
corcom http://www.brainshark.com/brainshark/vu/view.asp?pi=809828417
2) can't comment... any more info? sch. dia?
Tutorial
I think everything said on common-mode chokes is correct, except that the Cello amp seems not to have the usual common mode choke as stated above, but instead much larger chokes that are used in differential mode.
Post a schematic please
any info & an image of said choke would be very helpful
I'm not going to research all this and do the work for you
it's possible... could be a common mode for RF isolation as well a part of a zobel, dual purpose.
edit>
I would assume these audio amp output (common mode) choke applications are more benificial to class D and to lesser extent class AB.
edit>
Hello stellavox,
I use this configuration on my preamplifier (not amplifier like Cello). The inductor is used in LC configuration. It have many advantages (see my article). Model 4 preamplifier
Capacitor is not the only way to obtain continuous tension (if current crossing inductor is constant ).
Eric
stellavox said:...Has anyone used this technique and can share their experiences?...
Eric
- Power Supplies
- Common-mode choke discussion please
